Distributor Grand Marquis EFI 5.0
Discussion in 'Parts Interchange' started by Cemiat, Dec 15, 2011.
  1. Cemiat
    Cemiat Member
    Does this distributor work in my 302? that other pieces can take advantage of this motor?
    Tks
  2. rthomas771
    The 5.0 used a steel gear...you need a cast iron gear
  3. Cemiat
    Cemiat Member
    Can I change the Iron gear? or is better buy a new distributor?
  4. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    Buy a rebuilt distributor. The gears are quite expensive and have to be pressed off and on to the correct position. Since its difficult to get the hole for the roll pin lined up with the hole in the shaft, a new hole is usually drilled thru the shaft. Its not much more expensive and a lot less hassle to buy a rebuilt dist.
  5. comet289
    comet289 Member
    ohio
    73 comet
    this dist. is used for computor control systems you will need a pcm for it to work
  6. hotrod-daddy
    hotrod-daddy Member
    Rock Springs,Wyoming
    a 1971 Grabber with a 302/351
    Dizzy
    ....turn the gear 180 degrees and it should line up(y)
  7. maverick75
    Bingo! It's a TFI distributor which only works if you're running EFI.
