Frame Mounts
Discussion in 'Parts Interchange' started by darren2809, Sep 19, 2007.
  1. Columbus Comet
    Columbus Comet Member
    Columbus, OH
    I also recommend dealing with The Maverick Connection and Auto Krafters as both have lots of Maverick/Comet parts. Ebay is also a good source for parts.[/quote]
    I have dealt with Maverick Connection, Auto Krafters And Craig. All are great to do business with. I think they all are doing a great service for parts on our cars. I have also had a lot of questions answered on this forum. I thank all of you for the help. Joe Hubbard
  2. MaverickConnect
    MaverickConnect The Maverick Connection
    Parkersburg, WV
    1971 Grabber, & 1971 SuperGrabber
    Vermin infestation. Kinda cool though in a freaky sort of way...
  3. MaverickConnect
    Parkersburg, WV
    I have dealt with Maverick Connection, Auto Krafters And Craig. All are great to do business with. I think they all are doing a great service for parts on our cars. Joe Hubbard[/quote]
    Many thanks. I think we all try our best. :cheers:
  4. bmcdaniel
    bmcdaniel Senile Member
    Don't have any pics. The engine is located correctly, the block ball stud and the frame ball stud for the clutch z-bar align perfectly. When we did this we made a small square wooden frame and drilled four holes in it to simulate the four block mounting holes. We bolted the motor mounts to the wooden frame and lowered it over the frame horns. The motor mount bolt holes aligned with one of the existing frame horn bolts on each side. The ears on the motor mounts are wider than the frame horns so you can position them where you need to front-to-rear. a long horizontal bolt with spacers in front of and behind the frame horns keeps everything located front to rear. Put a level on the intake's carb pad and add spacers (cut pipe in my case) between the motor mounts and engine block until the carb pad is level.
  5. grbmaverickmo
    Aquashicola, PA
    Thats some old school fabbing there, I tells ya
  6. MaverickConnect
    Parkersburg, WV
    Yep, you gotta respect that. But after reading that, to me it makes $119 for the repos seem like a better deal... Bolt on and go!
  7. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
  8. bmcdaniel
    When I did the engine swap back in 1973 you couldn't get frame mounts from the dealer and there weren't any V8 cars in the junk yards yet. We had to improvise. It wasn't a big deal. Took all of about 10 minutes to locate the mounts with the wooden fixture and about 5 minutes to determine what length spacers were needed.
  9. grbmaverickmo
    Aquashicola, PA
    Yea what he said
