Instrument Cluster swap
Discussion in 'Parts Interchange' started by l24lalo, Apr 22, 2013.
  1. l24lalo
    l24lalo New Member
    MEXICO
    Hello all, I'm about to change my '77 mav instrument cluster as the original just became white powder like it happened to many member of this forum, I got an old style instrument cluster from a '72 mav and I already have the pinout configuration for the quick connector, I also have the old style plastic connector base as the newer style ( I think from late 73's) is different from this and already removed the cables and pins from it, I'll find out the cable configuration from the '77 connector in order to place all the pins in the right order onto the old plastic base; as soon as I finish the job I will write a tutorial for anybody who need to do the same :)
  2. 71gold
    great idea and good luck...:thumbs2:...:Handshake
  3. Banta
    Banta frankincomet
    madison indiana
    72 Mercury comet
    I just ripped mine out and in the process of building a new one. Just gota finish up the pods then fiberglass it
    Hottrod1991 and 14yearold like this.
  4. Banta
    Banta frankincomet
    madison indiana
    72 Mercury comet
    Other than the cost of the gauges. It only ran me about 30 bucks. And got to do away with the idiot lights
  5. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
    Thats pretty sweet
    i take it the big one is 3 3/8 like factory? Or a 5 inch?
  6. Banta
    Banta frankincomet
    madison indiana
    72 Mercury comet
    3 3/8 for my speed hut gps speedometer. And 4 2 in for oil pressure water temp. Fuel. And volts. Plus 2 for turn signals. 1 for high beam and 1 for brake fluid warning
  7. Banta
    Banta frankincomet
    madison indiana
    72 Mercury comet
    I'll update later as soon as I get my pods in the mail
  8. jtown77
    jtown77 Member
    Arizona
    71 Comet
    There is a difference in the way the dummy lights are wired too. If I remember right the older ones have a separate light for oil pressure and water temp. The newer ones only had an engine light. This is a 75 or 76 I think.
    Only an engine light.
  9. Banta
    Banta frankincomet
    madison indiana
    72 Mercury comet
    Mines a 72 and it had separate lights one for oil temp brake and alt.
    I'm only going to use the brake one because I put in a temp gauge sender in my radiator hose. And a sandwich plate on my oil filter for the pressure gauge and didn't need the alt light because I got a volt gauge
  10. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
    GPS is the way to go...more so if you change tire sizes allot or want to go with a newer trans that usually requires a vss..which you wont need now due to GPS
    you can get a 3 3/8 speedo with a tach built in too
  11. Banta
    Banta frankincomet
    madison indiana
    72 Mercury comet
    Speed hut is the way to go with them. Customizable in a lot of different ways Screenshot_2015-02-19-21-09-51.png
  12. Banta
    Banta frankincomet
    madison indiana
    72 Mercury comet
    20150313_191502.jpg just waiting on my oil pressure gauge
  13. Lord Tone
    Lord Tone Member
    '74 ford mavrick
    hey man that pretty sick how exactly did you accomplish that
  14. Banta
    Banta frankincomet
    madison indiana
    72 Mercury comet
    Started with a plastic barrel and traced my factory cluster on it. Cut it out and drew my gauges where I wanted em 20150303_190902.jpg then I got it all cut out
    And put some gauge pods in
  15. Banta
    Banta frankincomet
    madison indiana
    72 Mercury comet
    Threw some screws in to hold the pods in the angle I wanted em in. Then Spray foamed the back to add some girth and strength to it
