hi good morning my 70 maverick has a problem all the lights are working good except or the rear tail light when i press the brake pedal i t works and the turn signals too but the park light or the ones have to always be turn on does not work ,, i try everything the fuse , the ground,the switch i decide to run a ne cable directly to the battery does any one have the way i can connect its only for the stop lights on the back not for brake o turn signal please !
