Rack and Pinion Replacement
Discussion in 'Parts Interchange' started by 4DoorMav74, May 13, 2007.
  1. Slantsickness
    Slantsickness Member
    Tucson, Az
    1975 2 Dr.
    Probably not, unless your power steering pump is JACKED up. But you would know if it was 'cause it would tell you, with all the screeching, grinding, and belt squeeling noises.
    Lucky for you, most of the things that cause the problems you describe are simple to fix, like plugs + wires, carb needing rebuilt, and other normal service procedures. Unluckily, theres alot of things it could be.
  2. 4DoorMav74
    4DoorMav74 Youngin'
    Oceanside CA
    1974 four door Maverick
    yeah liek it starts but then dies after 2 seconds then after a few trys using starting fluid it will stay on for a lil bit but if i give it any gas it dies out
  3. drag72mav
    drag72mav Member
    Omaha
    does it die right after you use the starting fluid? just a hunch, could be the fuel pump, agree with the above statements too, possible plugs and wires, are you looking to do the work?
  4. 4DoorMav74
    4DoorMav74 Youngin'
    Oceanside CA
    yes it dies after using teh starter fluid and i am doin all he work myself..
  5. 4DoorMav74
    4DoorMav74 Youngin'
    Oceanside CA
    heres a pic of the place it is leaking from on teh driver's side of the engine...
