small block c-6
Discussion in 'Parts Interchange' started by autogamer117, Mar 31, 2007.
  1. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    chris you should have gone AOD , hook up with lentech, but its not my car i just got the idea
  2. RabidCustoms
    I dont think I can afford his stuff....thanks tho.
    ok,.enuf threadjacking..sorry(y)
  3. Mavericknutt
    Mavericknutt member
    BoisdArc mo.
    1971 maverick 2dr m2 front end coil over ladder bar rear suspension 472 ci. C-6 tranny
    I'd like to see a $150 c4 last on a transbrake. let's put it to a test you can have a c4 built with stock hard parts , and I'll build a c6 with stock hard parts and we'll put both of them on a transbrake and we will see which one lasts.:Handshake any bets on who will win?? you can have your 500 hp and I'll run what I have for the $$$$ I have less than $700 in my c6 that covers my stall (4000rpm on the brake)(all bearing,furnace brazed,billet front cover,anti ballon plate)transbrake, R super servo, 4R100 steel 6 pinion forward planet set.(lower 1st,and 2nd gear ratio)
  4. Andysutt
    Andysutt '72 Comet GT
    Conway Arkansas
    1972 Comet GT
    Well Im proud for you :)
    Like I said... Ive seen them built, and nobody was talking transbrakes to begin with.
  5. RabidCustoms
    get back in your cage nutt,:D ........its not your time to stir any pots :evilsmile
  6. Andysutt
    Conway Arkansas
    1972 Comet GT
    lol
    stirring pots huh. lol
  7. eddie1975
    Martinsburg, WV
    sold
    ficety(sp) aint he;)
  8. Mavericknutt
    Mavericknutt member
    BoisdArc mo.
    Not stiring the pot just pointing out that there is a reason:)
  9. Mavericknutt
    Mavericknutt member
    BoisdArc mo.
    hey I built my cage too:cheers:
  10. RabidCustoms
    yeah, you and I know that.....but thankfully not everyone thinks the same way :rofl2:
  11. Mavericknutt
    Mavericknutt member
    BoisdArc mo.
    If we all thought the same we'd all be satisfied with under 500 hp:rofl:
  12. RabidCustoms
    :hide: better hide,......if that dont start some #### I dont know what will:rofl2:
  13. Mavericknutt
    Mavericknutt member
    BoisdArc mo.
    what you started it(y)
  14. MaverickGrabber
    Cardington, ohio
    1972 Maverick Grabber 393w
    Wish I could of found someone to build my c4 for $150…to handle my small block and its not near 500 hp ….found its hard to find a harden input shaft for under $100 and the H servo go for as high as $60 ….a good converter is over $150…. :dancing:
  15. RabidCustoms
    I dont belive the converter counts as part of the tranny does it?.... yes its located there, and connects to,.but..........:huh:
