My New GRABBER Taillight Prototypes
Discussion in 'General Maverick/Comet' started by Acornridgeman, Dec 20, 2005.
  1. Acornridgeman
    Wisconsin
    Hunting season ended and it was too early for snowmobiling, so getting a little bored, I went into the shop and created a set of taillights for my Grabber project. They are not quite done yet. I still need to make a wiring harness and final sanding and finish coats on the trim mouldings.
    Being an old Cougar guy, I knew my car HAD to have a triple bulb sequential system. I looked very hard at what other people have done and came up with some possibilities. I did not want that "stuck onto" the back look but also didn't want to carve up the rear tail panel too much. I like the simple design of the stock tailights but I just had to make it my own. I had a box full of old beat-up taillights that came from junk yard pulls and parts cars, so I had a good supply of parts to work with.
    So here it is! It will fill the rear tail panel out across the entire back, leaving about 2 inches in each side of the gas cap. One thing I didn't know when starting this project, was just how much of a taper there is to the stock trim bezel. That was a problem and caused MUCH labor time for me trying to get it to look right. Overall, I'm very pleased with what I came up with! :clap:
    I have not seen anyone else with this design, I think I'm the 1st, so if anyone copies this design you can name it after me !! :biglaugh:
    and now --- the Eric Johnson GRABBER TAILLIGHT
  2. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Very nice work! Can't wait to see them on the car.
  3. Hawkco
    Hawkco Genuine Car Nut
    Rex, Georgia (GA)
    77 Maverick
    It's definitely unique. I dare say, unless you go into production, those will be a one-off set of tail lights.:tiphat:
  4. M.A.V.
    M.A.V. Yep,my real initials.
    Macon,Georgia
    And thus ...the Eric Johnson tail light legacy began.
  5. shaunh82
    shaunh82 Member
    Washington NJ
    71 Pinto sportsroof
    those are standard on the shelby maverick, right? :D
  6. sierra grabber
    sierra grabber Certifiable
    northern nevada
    i say YES, YES to sequential lights. very nicely made, cant wait to see them on the car.
  7. RabidCustoms
    interesting(y)
    its nice to see someone come up with different stuff.
  8. Mercurycruizers
    Venetia, PA
    very nice...can't wait to see them installed. Have always like the sequential tailights.
  9. don graham
    looks like factory, but it will be unique.(y)
  10. ronr11
    ronr11 Member
    hartsville sc
    71 maverick
    looks great eric what sequential kit are you going to use ?
  11. MikeG747
    MikeG747 Member
    Arkansas
    Great work Eric!
    Mike
  12. Tom Laskowski
    Tom Laskowski Member
    Bay Area,California
    (3) 71's,two V-8's and one 200 cid
    Wow! Very nice job.
  13. Mavaholic
    Looks great!!!!!!!!! Definately want to see them mounted and in action. How did you attach the bright trim together? I tried to use a Tig on them once when I was playing with my cyclops idea, but couldnt do anything with it.
  14. Craig Selvey
    Those look fantastic. Non-Maverick people will think they are factory.
    The only thing I would ad would probably be another set of mounting studs in the middle to help aid in stability when mounted to the car.
  15. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    I am highly impressed.
    Dan
