AOD (yes) install...
Discussion in 'Transmissions' started by 71gold, Aug 21, 2006.
  1. 71gold
    car went into the shop today for the AOD install...08/21/06 (y)
    i will get some pics. tomorrow...and a parts list...:yup:
    ...the parts i will be using will be...new...used and/or rebuilt...:yup:
    this threads main objective is to inform all as to how and what i did to install an AOD into a mav. with a 302 motor...and a list of parts i used.
    ...frank...:bouncy:
  2. Stefan
    Montreal, QC
    Sounds good... Ill move it to the special topics section once its done. If the thread gets messy, ill clean it up for you.
  3. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    with Frank...it will get messy :D
  4. Hawkco
    Hawkco Genuine Car Nut
    Rex, Georgia (GA)
    77 Maverick
    Frank, you could be a little more clear on what the topic of this thread is supposed to be?:rolleyes:
    I look forward to reading your posts. I plan an AOD swap into my '77. I await your results with anticipation.:clap:
    Frank's Real Good Friend Terry:Handshake
  5. Jamie Miles
    Alto, GA
    I've had a few
    Man, I coulda', shoulda' woulda'!
    (Damn, this thread is off topic already) :biglaugh:
  6. 71gold
    Went by the shop today...all is going well.
    he took an empty aod case and put the tailshaft and pan on it and used it to mock up the install.
    had to drop pass. header to get it up to be bolted on. we put the header back on and tomorrow we will take out the aod with it on to see if anything needs to be changed.
    got the trans. mount mod. done and will install it also.
    got the trans. lines cut and doing the flars in the morning.
    the driveshaft is not stock so i am going to get another one that is and see if it fits.
    the aod i am using is 1/4th in. longer than the c4.
    we hooked up the ...floor shifter...and it will work (y)
    got some pics. and will post them later...frank...:bouncy:
  7. Ryan
    Ryan Ford Addict
    Phoenix Az.
    Interested to see how the floor shifter worked. I wonder if the car your tranny came out of has a different linkage than the mustang AODs do. Look forward to the pics. My stock driveshaft fits fine with the aod in my car. Did your headers touch the tranny pan? I had to take my pass. side header off also to the aod in but with it bolted up and the header back in, both header flanges touch the seam between the pan and the tranny. I have Hedman headers, yours may be different.
  8. Jamie Miles
    Alto, GA
    I've had a few
    He said his AOD is out of a truck. I'd bet the shift arm is no where near the same as a Mustang.
    Frank, I have a few stock driveshafts laying around if you need one to use as a test fit. May be more of a PITA to get it down there then it's worth though.
  9. blugene
    Hey frank, I waited all night for them pics [​IMG] . I guess you ment later than I thought...:D
    I guess I missed where you mentioned what the trans came out of, Jamie said a truck. Which truck and year and what was the deciding factor(s) for your choice?
    So 1/4 in longer trans makes a difference in drive shaft choice? If so, I did'nt know that. I thought the part that goes unto the out put shaft was short/long enough to handle slight changes in lengths. If not I guess the yokes on me,LOL... Hope you get it with minimal troubles:cool:
  10. Jamie Miles
    Alto, GA
    I've had a few
    My bad, I was thinking of this thread. For some reason my mind didn't make the connection that this wasn't the same thread. :slap:
  11. Mavaholic
    Pay some one else to do it? :D :biglaugh:
  12. 71gold
    "you bet ya'" $250 for all parts including trans.
    $250 labor for install "you bet ya'" :D
    sold the c4 before i (they) pulled it...
  13. 71gold
    sorry about causing you to loose the sleep :slap: .
    the deciding factor...
    this AOD came out of an eighty year old mans truck he bought new...
    kind of like the ..."little ol' lady" car...this is the "little ol' man" truck :D .
    the 1/4th in. doesn't make a diff. it is my driveshaft is custom and it was longer than a stock...:bouncy: ...
  14. Hawkco
    Rex, Georgia (GA)
    77 Maverick
    That Phil Collins' song that says, "I Can't Dance" was about Frank.:rolleyes:
  15. Mavaholic
    Glad this thread isn't getting messy. :biglaugh:
