Paint and Body - Progress Pics
Discussion in 'General Maverick/Comet' started by Gene Fiore, Jun 15, 2014.
  1. Gene Fiore
    Gene Fiore Member
    Goodyear, AZ
    Thought I would start a thread of my Mav that is in for paint and body and post up some progress pics. A lot more rust and corrosion than anticipated but all fixable. Some of these issues have already had new metal welded in and looks awesome. :thumbs2:
  2. Gene Fiore
    Gene Fiore Member
    Goodyear, AZ
    Here are some more pics.
  3. Dave B
    Looks good, it's a lot of work, but the only way to fix it properly.
  4. groberts101
    groberts101 Member
    Minneapolis, MN
    Ouch! Makes me hope mine is as solid as I think it is once the paint comes off.
    Is this the same car in your avatar, Gene?
  5. bLaH_hA
    bLaH_hA Member
    jacksonville, fl
    72 mav grabber(sold), 1970 maverick grabber clone
    gives me hope that i can fix my quarter panel rather than replacing
  6. 55crownvic
    55crownvic Member
    colorado springs
    just a word of advice.......replace the entire bottom of those panels. Merely cutting out the obvious rust holes wont stop it. As soon as you are finished, the panels will pop a rust spot on the edge of the repaired area. Dont mean to be doom and gloom, here, but being a body guy for over 30 years, does have its advantages.
  7. bLaH_hA
    bLaH_hA Member
    jacksonville, fl
    I have the same problem on my maverick. Your saying just get new quarters, cutting quarters are out of my level about how much would it be to get someone to cut it out and replace both quarters?
  8. 55crownvic
    55crownvic Member
    colorado springs
    New quarters are the way to go, IF you can afford it, same with fenders, all tho most body guys can form a new replacement panel for the bottoms of those fenders and quarters. I myself just replaced the entire bottom edge of my right door, because when I stripped the paint there were a few spots that were about to blast out, better to fix the problem NOW, rather than re-do the repair in six months. A simple and cheap fix for the wheel arches on the quarters is to use the wheel arch from a fender. And the price depends an your location, the amount of work, and so on. Could end up being a few hundred for each panel, which isnt really that bad if its done correctly. Shop around, maybe there is a guy on here in your area that can help you out.
    Dave
  9. gunslinger68
    gunslinger68 Member
    Jackson, WI
    1970 Maverick-347,tr3550,9in,etc.etc.
    What he said. (y) 20 years bodyshop myself, rust is always bigger than what you see from the outside. It's easier to do more now, than redo it later. And when you are done, make sure to treat the backside of the what you repair, if you can get at it easy enough. I used a UPOL gun multi-directional wand, with por15 in it(I did this before refinishing). A good epoxy primer would be a way to go also.
  10. Gene Fiore
    Gene Fiore Member
    Goodyear, AZ
    Yes...it was a 50 footer for sure! LOL
  11. Gene Fiore
    Gene Fiore Member
    Goodyear, AZ
    Actually the passenger rear qtr is being replaced with a new one. It's hard to tell from the pics but it had been hit and repaired terribly...there was an inch thick layer of bondo from the wing window all the way down to the wheel well...and the metal is all rippled and messed up. Driver side is fixable.
  12. Craig Selvey
    Is the car originally from Arizona? Looks like a snow belt car from around here.
  13. Paul Masson
    1971 Grabber
    Looks like you're into a lot of work, but I've seen A LOT worse! Good to see that you are cutting out all the rust and welding in new metal--it's the only way to go. Looking forward to progress updates!!
  14. Gene Fiore
    Gene Fiore Member
    Goodyear, AZ
    No not from Arizona. This car was purchased new in South Carolina and was in Ohio when I purchased it.
  15. Craig Selvey
    That explains the rust.
